littleitaly1990 Posted September 9, 2007 Report Share Posted September 9, 2007 kappa perfect 6.5 General Power Handling, RMS 100 Watts Power Handling, Peak 400 Watts Frequency Response (±3dB) 75Hz - 23kHz Sensitivity 90dB Impedance 4 Ohms Crossover Frequency(ies) 3.5kHz, 24dB/oct Mounting Depth 2-3/4" Perfect Mid-woofer, 1" Perfect tweeter kappa 6.5 General Power Handling, RMS 90 Watts Power Handling, Peak 270 Watts Sensitivity 95dB Frequency Response 45Hz - 25kHz Mounting Depth 2-3/16" Impedance 2 Ohms Since the perfects have much better quality I want them up front in my jeep grand cherokee. What amplifier will give all 4 speakers the proper amount of power? A vitrolic, megalomaniacal sadistic psychopath. Link to comment Share on other sites More sharing options...
thegr8cody Posted September 9, 2007 Report Share Posted September 9, 2007 power acoustik ps4-1200 1200W Max, Power Series 4-Channel Amplifier RMS Power Output: 4 ohms: 100 watts x 4 channels 2 ohms: 125 watts x 4 channels Bridged, 4 ohms: 250 watts x 2 channels PWM MOSFET power supply High or low level inputs with floating ground Variable low-pass crossover (40-120 Hz) Variable high-pass crossover (150-1,500 Hz) Variable 18 dB bass boost at 40 Hz Tri-Mode capable 3-Way protection circuit Platinum-plated RCA terminals RCA preamp outputs Frequency Response: 10 Hz - 30,000 Hz Dimensions: 13"L x 11-3/10"W x 2"H 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
AI James Posted September 9, 2007 Report Share Posted September 9, 2007 sundown 100.4 US Amps MD43 Since the perfects have much better quality since you care about this i wouldnt mess with PA Link to comment Share on other sites More sharing options...
