What 4 Channel Amp?
littleitaly1990
kappa perfect 6.5
General
Power Handling, RMS 100 Watts
Power Handling, Peak 400 Watts
Frequency Response (±3dB) 75Hz - 23kHz
Sensitivity 90dB
Impedance 4 Ohms
Crossover Frequency(ies) 3.5kHz, 24dB/oct
Mounting Depth 2-3/4" Perfect Mid-woofer, 1" Perfect tweeter
kappa 6.5
General
Power Handling, RMS 90 Watts
Power Handling, Peak 270 Watts
Sensitivity 95dB
Frequency Response 45Hz - 25kHz
Mounting Depth 2-3/16"
Impedance 2 Ohms
Since the perfects have much better quality I want them up front in my jeep grand cherokee.
What amplifier will give all 4 speakers the proper amount of power?
A vitrolic, megalomaniacal sadistic psychopath.
power acoustik ps4-1200
1200W Max, Power Series 4-Channel Amplifier
RMS Power Output:
4 ohms: 100 watts x 4 channels
2 ohms: 125 watts x 4 channels
Bridged, 4 ohms: 250 watts x 2 channels
PWM MOSFET power supply
High or low level inputs with floating ground
Variable low-pass crossover (40-120 Hz)
Variable high-pass crossover (150-1,500 Hz)
Variable 18 dB bass boost at 40 Hz
Tri-Mode capable
3-Way protection circuit
Platinum-plated RCA terminals
RCA preamp outputs
Frequency Response: 10 Hz - 30,000 Hz
Dimensions: 13"L x 11-3/10"W x 2"H
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
  • Who's Online   1 Member, 0 Anonymous, 1392 Guests (See full list)
