Building my 2nd box ever, simple question
Trâgîk
Your box looks good, nice job. resin will not stick to silicone at all, it will soak in and bond to mdf very well though you dont need to sand it so fine, but should be alright.I owen a fiber glass shop we sand every thing else with 80 to 24 grit, but on mdf the resin will soak in just keep that in mind
But the resin will seal everythin up right? When i put the resin in, do i sand it after or just let it be? I havent worked with it much at all so its going to be a learning experiment
-----SELLING EVERYTHING----
2 DC sound labs 3.5k's (still avail)
2 HDC312A D1's (still avail)
5 XS Power Batteries (1 d3400 and 1 d1200 left)
4 runs of knukoncepz 0 gauge (have all the wire still)
DC power 270XP alt (sold)
RF T1 6.5 components (both sold)
Powerbass XAX 4160 (still avail)
Custom built box 4.75^3 tuned 34hz (still avail)
ive been building boxes for 2 years and i dont have a box for myself that looks this nice lol... looks like this summers build needs to get started.
Thanks man! Thats what little carpentry skills comin thought. Lol. Hell yea get started, ima do something different this summer tho most likely
Your seams look good so it should seal it fine, they make a lot of fillers you can add to resin to thicken it you could make a thicker putty and fill the coners and shape them.
Are you talking about something like the resin with fiberglass strands in it all ready(hair resin i think its called) or maybe even like fiberglass bondo stuff? I have both. The bondo is thicker but idk how it works with the mdf. Ill test it to see how it will work
So i just fiberglassed the inside of my box, ill have pics up soon but i only used mat on the back wall and then put resin in the whole box except for in the port. Should i do the port also? And once everything cures, do i sand the resin or leave it like it is??? I am going to put one more coat of mat and resin on it and i k ow i have to sand between coats but do i sand the final coat of resin? This is my first time working with fiberglass at all and need a little help please
Damn where is everybody when you need em!?? Lol
ok so here are the pictures, a few from yesterday but most was from the fiberglassing i did today outside becuase it was gorgeous out here today! and keep in mind this is the first time ive done fiberglass, just watched steves videos and many others.. and i could really use some advice from others too..i put two coats of resin in the whole box except only one in the port which i will be doing another one when i to the top of the box when i put it together.. i used one layer of mat on the back and then when that dried i sanded it a little bit and then used a layer of fiberglass cloth...i liked the cloth better, it was easier to work with..i just used all generic, bondo brand, stuff from home depot and lowes..all in all i think i did ok..the inside is really smooth, now to i leave it like that or do i sand it with very fine paper(400 grit)? On the back wall with the 45s and the triangle thing im going to use bondo to round it a little and smooth it out where i used the cloth but what about the rest of the box?? do i skim coat the whole thing with bondo, fine sand and then paint or what?? i need a little help on where to go from here..
and how the hell do i get this shit off my arms??? lol i have acetone,will that work?
now this is after sanding first coat
more pics..after the second coat
  • Who's Online   0 Members, 0 Anonymous, 1802 Guests (See full list)
