no. if your sub is a dual 4-ohm sub you cannot wire it into 4-ohms.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
so after done some search on google i want to wire the sub to the amp with 8ohms
it's all ok but i dont known what cable is the green between - and +
is a positive cable or negative? or what is his name?
That's just a wire used to connect the voice coils in series. A single strand of speaker wire would work fine.
try 2 ohm bridged, set the gains accordingly... i have a $50 walmart 2 chan that isnt even rated for 4 ohm bridged and i am running it at 2 ohm bridged.. just set the gain to put out what its rated for at 4
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
  • Who's Online   0 Members, 0 Anonymous, 518 Guests (See full list)
