My Civic Build 2 Fi 15" Bl's On 2 Sundown Saz 1500d's
Carpet will be in on Monday or Tuesday. Says Monday, but that is Martin Luther King Day so i don't know if UPS will run.
J Black, not gonna have everything done in time. Heck that is this weekend. Tonight I thought. Still waiting to get it all in the car still a couple of weeks out yet. But I am getting closer. I will let you know when I get it done, cause I will make a ride up to see ya.
Well I am taking bets from everyone to see if my amp will let out Magic Smoke or will it ride at this ohm load. You guys can comment and put in your input. I am gonna say it will hold up. I played around tonight and cut the wire that connects the coils. I am gonna have to go and buy some sort of connectors to connect the subs cause the holes in the sub connectors are tight. I just want to make them nice and clean looking. Here are the pics.
Posted Image
Here is what it reads when I measure the 2 subs wired up parallel.
Posted Image
P.S. That small wire won't be in the box. Gonna use the 8 guage for the connector piece just didn't want to cut untill I can get some connectors.
2 bolts..I never would have thought of that. What do I do just Drill a hole in the box insert 2 bolts, put ring terminals on the inside wires and attach them to the bolts? Ring terminal the wires coming from my amp to the bolts where they stick through on the outside of the box. Any certain kind or grade of bolt? Any certain metal?
brass/copper or i used just a grade 5 zinc. depends if you want to make it so that you can disconnect it easily (which i dont think youll need to). put the bolt through either way, put your ring terminals on, but make sure the only thing touching the box is a washer. it has to lay flat on the box to seal up the hole. if you need, i can explain the order with the terminal, washer, nut.....but im sure you can figure it out ;)
you typically use a little bit more wire this way, but it works.
And now the carpeting begins. I will have more pictures later..Gotta carpet this beast.
Posted Image
All i have to say is ur civic is pimp!! I like it, im looking for one like that myself
1987 HONDA CIVIC
(1) Pioneer Head Unit
(1) Kicker KX650.4
(2) Alpine Type E's
(4) MA Audio MA80XE's
Man to hell with wrappin presents..Now I know why my momma didn't teach her son how to wrap a present..But it turned out decent for a first time box builder/carpet man.. What you guys think?
Posted Image
Posted Image
Posted Image
We ain't gonna look at the sides, it ain't great..But you won't see the sides anyway. Just the front. Cause it will be walled..
Looks really good, I know I had a hell of a time carpeting my box and it is 40" wide 36" deep and 28" tall. But yah yoours looks really good nice job and nice job on the whole build in general.
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
