well like the title says im a noob when it comes to this, i love bass and have had systems before but nothing even halfway decent or that even almost sounded good,and right now i have a question.
i bought a jl audio 12 w6 today with a jl audio 250/1 amp, my question is this the right amp for this sub? i have a ported v-tech box that the sub is in, i had someone install this setup for me today in my 2003 kia spectra and i have everything on the amp tuned down and the cd player bass is -8 but if i turn my volume passed 20 sometimes 18 when the bass starts to hit harder the amp shuts off. so i un hooked everything so wouldnt hurt anything,
can anyone help me fix this type of problem? i will take some pictures tomorrow morning and better describe the guage of the wires and the size of
the fuse connected at the battery, but to my knowledge the wires are from a starter kit at advance auto cost like 19.99 its very small. and the fuse at the battery says 100a so im guessing 100 amp?
What voicecoil configurations?
Well i believe the sub is rated for 500 watts RMS. So its small for it. Post up the pics so we can help. Welcome to the site bro. Remember to use the search button before asking questions. Let us know what wires are you using for power and ground. Just read the side of the wires.
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
by voice coil setup you mean from the sub connections to the box connections? if so when i watched the guy put it in he used speaker wire and put one wire from positive on the sub to positive on the box and one wire from negative on the sub to negative on the box
and thank you for responding so fast ill have pics up first thing in the morning
no, like what are the specs for the subwoofer voicecoil. and check your grounds, or make sure the ground is sufficient.
going to take pictures now and i beleive the rms is 500w for this sub and if thats right i need a larger amp if i want to play this sub continuosly?
no, you need a 500w amp if you want to play the sub at 500 watts. As it is right now you can play it continuously at 250 watts, which wont hurt anything or cause any issues, only downside is you are probably 2-3db lower than what the sub is capable of.
Team DC
well im going to take pictures of how everything is setup, so the fact the amp cuts off if i turn my cd player up loud could just be simple wiring?
when i was taking pictures i turned my car on to listen and noticed that the fuse at the battery is very loose and by that i mean if i held it and pushed it in the amp wasnt cutting out as much but if i let go it would just stop so im just guessing thats a problem.
If I read correctly you had this installed? Or did you install it?
1989 E30 325i BMW (New Car)
iPad 64GB 3G (COMING SOON!)
1 12" DC LEVEL 4 w/LEVEL 5 Soft Parts
Ported box - 1.5 Cubes tuned to 33hz
Sound Stream STL1.1200D
4 Gauge Stinger Wire (+ & -)
8 Gauge Amp to Sub Stinger Wire
Tsunami Mini ANL 130 Amp Fuse
AUDIO WRAP SUPPORTER!
  • Who's Online   0 Members, 0 Anonymous, 526 Guests (See full list)
