if you mount these in the plastic panel, put a ring behind the plastic for the speaker to screw into. i would bolt the panel to the metal so the plastic panel doesnt flex as much. if that plastic flexes, it'll sound like shit.
where did you look up mounting depth? ive always seen the CTX was 3" deep.
pm me if you want to talk about trading.
Edited by skittlesRgood
well a few posts above i quoted something a guy from SSA told me with putting them right into the panels like that, and yeah i would put medf behind it for the mid to mount to
but he is basically saying make a small enclosure using my door panel and the inside panel, which IMO sounds like a good idea
but before i go and do that im gonna try a few more things.. once this weather gets better of course
I had the same problem with mine, But with the 3/4ths MDF ring it gave me just enough room haha.
yeah, what i can easily do is flip the mdf ring over and it'll stick out 3/4 instead of 1/2 (due to the flush mount) so i can try that and shit
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Here's a way that I'd do it.
Mount the speaker in the door panel in place of the factory grille.
Make and stack a series of rings to go from the cutout on the plastic panel to the stock mounting location (the metal of the door.) screw the rings to the door, and glue them together to get them out far enough to align with the door panel.
Your speakers will look like they are just mounted on the door panel but they will actually use the door as the enclosure just like you want.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
yeah thats almost like what is posted above except without the fiberglass, and this involves more cutouts, which i may try before i try fiberglassing.. doesnt look like it would be so much fun to remove fiberglass if it didnt turn out right
Team Sundown Audio
Well, I've done it once before and it worked out pretty good. Not the easiest way to go about it, but it is simple and effective. If you have no experience fiberglassing, then I'd try doing what I said first. You should get a good result.
My Saab 9000 build
but will the front of the speaker hit the panel when you do that? stick a small allen wrench in the speaker grill in the door and see how deep it goes until you hit metal, or wood.
yeah ill look into it, thanks :)
Team Sundown Audio
well my RSD mids hit the panel (on excursion only) which is why i had them crossed around 90-120hz in that range.. but my adapters were 3/4"-1" (they were on an incline the 1" was at the bottom corner and it decended into 3/4" up top to put the speaker on an "upward" angle) and i hit with those the surround hit
Team Sundown Audio
for those of you with my type door panels, when you mounted the mids in the door how much of the door panel did you physically need to cut?
Team Sundown Audio
