1 ohm?
Question: if I have a 2 ohm dvc sub & I wire it down to 1 ohm according to 12 volt.com, but I make the mistake of running my pos & neg from one coil, to the amp. Rather than a pos from one coil to the amp & a neg from the other coil to the amp. Does that make a difference? I had the sub wired that way at a DB drag.
Yeah it makes a difference you were running a 2 ohm coil to the amp. That is ifyou only hooked up that one coil, meaning you were only using half the subs potential. It was hard to understand what you were exactly saying but thats what i got from it. If you hooked up both postitves to the amps positive and bothe the negatives to the amp then you would have 1 ohm load on the amp.
-----SELLING EVERYTHING----
2 DC sound labs 3.5k's (still avail)
2 HDC312A D1's (still avail)
5 XS Power Batteries (1 d3400 and 1 d1200 left)
4 runs of knukoncepz 0 gauge (have all the wire still)
DC power 270XP alt (sold)
RF T1 6.5 components (both sold)
Powerbass XAX 4160 (still avail)
Custom built box 4.75^3 tuned 34hz (still avail)
Yea, that makes sense. Thanks man. 12volt diagram is that particular way, so you can have 1 ohm with just 2 wires, rather than 4 wires. I think.
Eclipse cd7000
I don't think it make a difference !
(-) to (-) on sub, to amp(-)
(+) to (+) on sub, to amp(+)
Should be good !
If I'm wrong, tell me please !!!!!!
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Should be good
your right, at least on a mono amp it doesnt matter
Ahhh. This video is exactly how I had the sub wired, and I thought I was making a mistake. But if you can tell me that the wiring in this vid is correct, then all is good.. I think it is ok, because +&+ are together, and -&- are together and they are both connected to the amp. It is wired different than the 12volt.com but I think it is the same circuit, Parallel right?
Yes thats what it is and its fine
  • Who's Online   0 Members, 0 Anonymous, 1365 Guests (See full list)
