Whats up people.. I've been into car audio systems for a few years now. And I'm ready to start experimenting with two amps to start off.
My main questions are when should more batteries and alternators be added? If anyone has some tips/info to throw in that would be great!
[drivin' that grey goose]
More batteries and alternators should be considered when the maximum current draw exceeds the vehicles current output... To find this there are simple formulas that can be used to determine this...
Whats the best way to go about this?
I would also like to know, because I am going to be getting about a 2k Watt system for a honda civic running off stock battery and alternator. Was wondering if I should cough up something for something else.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Hell yes, unless u want to ruin your electrical system.
I would say on a complete stock car, you could run ~800 watts, but not @ full tilt all the time. It is also recommended to do the Big 3.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
You received AN answer that pretty much summed it up. There is no number of batteries and alternator upgrades on a chart to correspond with hoe many amps or subs you're installing.
Everything is based off of the current draw you will be pulling. Maybe a list of what you plan on using and then we can help you figure out an electrical system capable of proper use. Your asking a vague question but expecting a well thought out, specific explanation.
It doesn't matter if you're installing 10 200 watt amplifiers, or just 1 2000 watt. Current is what matters when planning your electrical.
Not every car is the same, there are many factors to consider. For his vehicle...I would assume it has a 90-110 amp alternator.
The other question is what amp are you using and how is it wired? A Sony 2000 watt amp is not making 2000 watts so...yeah...lol.
K well for me, I have a stock alternator, the battery is not stock but not amazing, probably just some normal car battery from autozone or something. I am going to be running a RF T400-4 for sure, and either a T1000-bd or a T1500-bd.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I personally would spend the money and upgrade the electrical long before I even work on getting the equipment. I wouldn't say you need to upgrade the alternator but it will make the world of difference. Definitely upgrade your big 3, starting battery, and adding another battery would be nice. Look to XS for some good stuff.
And what subs are you planning on running?
Edited by TeamHT
  • Who's Online   0 Members, 1 Anonymous (See full list)
