Mechman Alternators
whats the safe way to run 16v daily ? I have a 16v ext reg alt. Im sure i cant run it at 17.9 daily. whats a safe voltage to run the alt at without hurting anything ? Shud i put it on a switch and jus tun it off when system is not in use ? or just turn the it down when im riding around town, and raise voltage when in comp mode or doin demos ?
4 I.A. Warden 15s
8 I.A. 20.1s
2010 140.0-149.9 Bass Race Points Champ/Over all champ
2010 140.0-149.9 Bass Race S.C. Regional Champ
2010 FL Regional Middle Weight Champ
2010 INAC Middle Weight Bass Boxing Champ
If you are running 16 volt system then you would have batteries that are made for 16 volt system and a step down for the vehicle to operate at 12 volt system, so leave it at 18 volts charging and rock on. You won't want to raise it up and down, unless you are short on the current demand.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
i have dual alts, 12v and 16v with 16v batts (14)
4 I.A. Warden 15s
8 I.A. 20.1s
Then run the 16 volt ones in float mode for the most part with is 17+ volts and then when you are pulling them down raise up the reg to 18+
Evo X build log
If you have two alternators, just run the 12 volt alternator to a 12 volt battery to power the vehicle, and run the 16 volt alternator to the 16 volt batteries to supply the sub woofer amplifiers. 16 volt AGM batteries should be charged around 19 volts in order to receive a proper charge.
can i run my alt at 19v daily is my question with out hurting the alt ? I was told no, they arent ment to be run like that daily. My 12v alt does run my car, thats its sole purpose in life lol. Just dnt wana have to rebuild an alt again.
4 I.A. Warden 15s
8 I.A. 20.1s
If the alternator is built properly, it can run at 19 volts all the time.
That is not to say it can run at full OUTPUT all the time, but maintaining good condition 16 volt batteries should be no problem.
  • Who's Online   1 Member, 0 Anonymous, 322 Guests (See full list)
