my 08 malibu ltz wont crank up
Did u run wires, or cut anything, looks like either you chaffed some wire or an ign isnt coming on.
If it is an ign that will explain the no crank.
Accy, second accy, second ign and starter are all the same wire.
Makesure all the stock grounds are hooked up.
Double check the main fuses under yhe hood.
They will labeled, ign..etc
Double check you hooked up the cable that goes straghtto the starter.
It will be a 6awg wire,pos.
Now triple check it.lol
yeah its connected,i checked like 5xs
and i cant miss it because its bridged to the big terminal
so once that one is hooked in,it connects the started right away
and i already connected the positive and negative together
it didnt do anything :shrug:
damn i'll keep trying
Service ESC is the Electronic Stability Control, idk why that would not let it start.
My mom has a '10 LTZ and hasnt had a problem with hers, sucks that you're having an issue.
With the battery unhooked, try and crank the car a couple times to get any remaining charge left in the system out.
You might also want to try and call a GM Dealership and see if they can talk you thru it over the phone...some dealerships are nice like that.
yeah but the local chevy dealer is closed
i already called and there the ones i'm planning on taking my car to.
they're like 1/2 a mile away from my house lol
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
I'd try what speedball1978 suggested.
I own a 2001 Impala LS and it's got some stupid things you gotta do with the gas pedal and the headlight switch to reset some messages, might work for your LTZ.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
i have the same car but a 09 model, i had my battery out for 2 days as well, got the same thing, turn the key to the on position and press the gas pedal 5 times and hold it down that's what i did to reset the ecu
thanks!
ill see if that works :drinks:
could be when i was modifying the stock plastic,
it was worthless and i regret it
cus the d3100 doesnt even fit with me modifying the plastic lol
i guess things have to happen to teach me a lesson.i learned :peepwall:
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
found some info that might interest you
2001 chevy malibu won't start!!?
By Yahoo:Tracey at Yahoo!Answers.com
We have replaced the fuel filter, fuel pump, spark plugs and wires and the car still will not start. Parked it at night went out in the morning and it would not start. I have never had a problem with it before this. The check engine light never came on. We are out of... Read More
I had the same promblem with mind. It was the security system. I have a number to a guy that fixed it for me. What he did was turn the key on off let it set for some time then some other producers and now it starts. let me know if you want to contact him. My number is... Read More
maybe your passlock security system came on. if you turn the key to on position, and wait for ten minutes. if this is the problem the security light will come on, and when it's reset it will go off. when the light goes off turn the car off, and then try starting
since you have a remote start button on your key, try starting up the car using the remote start.. see if she starts up
yeah i tried
and it wont let me
julio(99s10walled)
told me to do that yesterday
and it didnt work
i tried that this morning like 3xs and still
no luck
but i tried about the foot pedal thing to restart it
and it didnt work
ahh =/
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
01 isnt the same data system as an 08.
i tried that yesterday
too and didnt work eighther
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
  • Who's Online   1 Member, 0 Anonymous, 1438 Guests (See full list)
