my 08 malibu ltz wont crank up
maybe pressing the pedal more than 8 times will do something to it...
maybe the battery just needs to stay hooked up for a few hours to reset the whole circuit..
i had it hooked up all day yesterday since 7 in the morning
its 9:44am here in cali
so its been hooked up for more than 24hrs
a guy wrote this on one of the forums
cant find the link but copy and pasted this instructions
of how to reset the ecu to any car.i dont know if this would work
but im willing to try it
here it is:
ECU reset
This is how you effectively reset your ECU, after a major power mod or some sort of boost or fueling change/increase i.e. an EBC or AFC:
-Unplug the negative terminal from your battery
-Get in car and pump brake pedal a few times, or until no electrical functions work (tail lights, dashlights, etc)
-let car sit for 45 minutes
-reconnect the negative terminal and take the car for a "spirited" drive, coming as close as possible to redline in each gear (BE SAFE!!!)
-do a cool down drive and make sure you use good gas from then on
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
man the only thing i could think of left to do is get the error code programmer.. whatever that damn thing is called... it tells you what is wrong with the car..
scanner?
So does the car even try to start or won't turn at all?
it doesnt make that noise that it wants to start
its all quiet
i have to stick my head out of the window
so i can hear if my car is making any noise
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
That's not very accurate though, especially if here's a problem with the ecu. When I was having this issue with my car I hooked up the programmer to it and it indicated a bad abs power module....bs! After resetting the ecu I had no more bs error codes and everything has been working fine and its been over a year now.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
now this might be or sound stupid but hold the lock and unlock button together on ur cars keless entry remote see if it will reset itself and then see if you can get it to start. it might take a minute for it to reset if it does at all but id say hold those buttons for atleast 30secs but if nothing happens after a min then it probably aint gonna do anything.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
i bet you autozone could rent out the scanner for a small fee? or maybe someone already has one..
my friend has one,he as well owns a shop
those things are like 7k
but he even said it wont work for my car's issue
he went to my house to check it out
and told me where's my manual book,sadly someone took it out
whoever was cleaning out my car,never paid attention to it than right now
sucks
still cant find the damn thing
pure FAILs lol
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
12-14-2009, 01:11 PM #20
RFB7105
CMF Rookie Member
Gallery: 0 Re: Service Traction and ESC
I had a similar issue with 2008 LTZ 3.6, and the dealer found a bad solonoid and connector. Once replaced it never came back and the car is running fine.
  • Who's Online   1 Member, 0 Anonymous, 1574 Guests (See full list)
