lilmex1can Posted March 1, 2011 Report Posted March 1, 2011 I have a SSL EV3000D amplidier pushing 2 Kicker CVX 12's. I was told either buy another and put one on each sub or get a better amp. Is this amp really that bad? Here's the specs Max power 1 ohm 3000W X 1 Max power 2 ohm 2200W X 1 RMS power 2 ohm 1700W X 1 MAX power 4 ohm 1500W X 1 RMS power 4 ohm 1200W X 1 Signal-to-noise ratio 105db THD at RMS output 0.01% Damping factor 125+ Dimensions (13” L x 10” W x 2-1/4” H) I have the subs wired at one ohm but what these specs say are max power.
keepinitloud Posted March 1, 2011 Report Posted March 1, 2011 yeah soundstorm amps are not a really good amps not sure what they put out power wise realistically you would have to clamp it but its not worth it just use it for now and start saving up your money for a better amp to run on your kicker subs 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
ChevyBoy95 Posted March 2, 2011 Report Posted March 2, 2011 Max power 1 ohm 3000W X 1 Max power 2 ohm 2200W X 1 RMS power 2 ohm 1700W X 1 MAX power 4 ohm 1500W X 1 RMS power 4 ohm 1200W X 1 forget those numbers completely SSL amps are not the best out there... my brother has one and it has treated him great and absolutely slams his L7 15. But i have dealt with there amps also, ill sugar coat it and say that it was a bad experience. you need an amp that does 1500 rms (at the ohm load your running your subs). If you need decent bugdet amps, look into hifonics (not the HFi line) or soundstream. Theres also Audioque and there 1200D, etc. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Benji0687 Posted March 2, 2011 Report Posted March 2, 2011 Hmm...trying to think of the nicest way of saying this. Soundstorm amps are not good whatsoever. Every time I've dealt with one I have not enjoyed the experience and was very disappointed by its performance. 1989 Chevy Caprice Classic350ci V8 High Performance JVC Arsenal HU JL XR series components Infinity Reference 6x9s Pioneer Premier 4-Channel Clarion 2-Channel Rockford Fosgate Series 1 2-Channel Fusion 2000.1D MTX Crossover RF, Knu, Kicker, and Monster wiring NVX VCW 12in. Sub **Won on here from the Sonic contest!** *Build log coming soon!* Starting all over pretty much which the gear listed...lost almost everything I had, including my life. Never take life and what's in it for granted.
