Hey,
Today i was listening to my music as usual and for the first time ever my battery died, had to bump start my car and leave it running for a bit. I'm running a bog standard battery and alternator so I've decided its time to up my power a bit as my system is starting to become a strain on standard power.
I've got a 4 channel 100wRMS x 4 Vibe Blackbox Amplifier and a 1 Channel 400wRMS Orion Cobalt Monoblock. I'm pretty sure both have 2x 30A Fuses.
First of all can anybody tell me what the formula is to work out how long i can play music at full volume for before my battery is dead? I'm pretty sure my battery is 50ah i think. How can i use that along with the total of 120A from my Amps to work out how long until my battery is dead.
I also need some advice on what alternator to get, my car is a Volkswagen Golf Mk3 if that helps at all.
And what battery to get. I have absolutely no clue what numbers i should be looking at on batteries, there's CCA, ah and others. But i don't know which one means how long the battery will last playing music before it dies.
I'm sorry if anything i say doesn't make sense, there's so much to learn about batteries that I'm getting quite confused.
Edited by Migz
So...you're playing your stuff for a very long time with the car off, and it dies. Why not just keep an eye on your voltage then? You'll have no problems.
Need an install? Hit me up.
[email protected]
hey everyone my first time posting....i need some advice about alternators..i have a 95 integra stock alternator running 1 500/1 JL amp, 12 inch RE Audio Se-x dual 2 ohm subwoofer, 500k farad cap.....1 zapco ag360 for mids... the problem is when im bumpin my lights dim then power to the system cuts then turns back on!!!! i need to what kinda alternator if i upgrade any help pls
BaDaZZ619
To the OP, depends on idle output of your alternator. You have to know exactly how much demand you have in amps, and then how much output your alt has in amps, whatever that difference is you have to maintain by battery. If the difference is over 100, then you will drop voltage generally to resting voltage which is ~12.8 on an AGM battery, on a standard battery general ~12.5, IF you are want to play your stuff for hours, then you need to look at RC of the batteries you select, the ah rating is done at a low and slow current draw so means basically nothing in car audio. And the formula to figure this out is a exponential inverted parabolic function, kind of pita to calculate and requires some calculus knowledge to calculate correctly.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
just add a battery
just add a battery
Or get rid of the cap, not doing a damn thing.
Evo X build log
just add a battery
For the extra battery is an isolator needed? And should I remove the cap or get another one with higher capacity? Thanks
BaDaZZ619
I installed some special terminals on my battery which tell me the volts in my battery for just this reason, but A.) I didn't realise my battery would run low that quickly so i want to help make it last a bit longer. And B.) Im not too sure how im meant to know when its low, because when my bass hits my voltage drops, but then when the bass goes my voltage comes back up. How can i tell if the voltage is low because it seems to just go back up to normal when i'm not playing anything :/
Not sure what the output is at idle, but it says 70 on it, although thats most likely when it's properly going. I'll see if i can find out what it is at idle, its a bog standard VW alternator though. And how would i find out how much demand i have in amps? I know i have a total of 120 Amps worth of fuses on my amplifiers so it cant be more then that. But how do i know exactly what amount is being used?
Roughly what kind of RC rating will play for how long?
Thanks for the quick replies!
  • Who's Online   0 Members, 0 Anonymous, 696 Guests (See full list)
