Kickerkid: It's so easy to get that perfect, clean edge with a router. Just need to make sure to keep the bottom flat against the box and go slow.
Thanks!
If it stops raining I'll get back to work.
Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier
Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
Holy f&;! S$,!
This thing gets IT! I put the port in with 1" screws and it blew the port off the box. Its just shy of raining so Im not sure if I will get a video tonight, but soon.
Btw I'm grinning ear to ear
Once again, holy sh!t. F-ing slams, gets the lows much better. It's falling into the high 11 volt range though. I have to get those batteries and that alt in there.
Ram designs ftw
Still freaking raining here, but it will levitate a plastic bag at the center console with the windows up. I need some serious second skin help. Next step is to get those batteries/alt in, and seal the trunk off
Videos when I can.
Will have to break out the meter too and see what it does on the mic, before I second skin it.
142.3?? thats with the 2500.1bdcp? should be a lot louder then that. thats a lot of power and air movement to only be getting a 142.3
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
80hz to 20hz sweep wasn't working, so I couldn't get a good base range to start with.
Also the box has a couple of leaks that need to be addressed
I have really bad voltage right now, the alt and the batteries aren't in yet.
So by theory:
13.8v x 150a = 2070 watts
11.1v x 150a = 1665 watts
That is without box rise, or any other factors
And it's not sealed from the trunk.
P.s. it was also doing 141.8 at 30hz and 142.3 at 40 I think. I was starting to feel bad for the neighbors so I shut it down.
