Poured Seafoam down the wrong hose
Alright, Please try not to bash me :(, my engine is running fine, but I am pretty sure I poored seafoam down the wrong hose and I am not sure what this hose does. It runs from the air filter box to the top by where the engine oil is located, and it was pulling air towards the oil side. I know now that I am supposed to poor the seafoam in the brake booster vacuum line which I think is located behind my brake booster behind my battery by the fire wall. If anyone could tell me what hose I poored this down and where would the seafoam go from there that would be great. I also put it in my oil about 70 miles ago, so I am going to go and get it changed now as it is pure black :D there goes $50 dollars down the drain as this oil change only had maybe 700 miles on it, and its synthetic too, oh well, anyways, thanks for the help !!!!
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
its a air breather tube ya basicly poured the seafoam in ya valve train which lead to ya oil pan after it goes threw the maze. cause right now ya usen your sea foam as a engine flush
Team DBs (Driven By sound)
Is that a town and country? It looks like a recirculation hose to burn off more emissions in combustion chamber.
thats a "vacuum" line from your intake to your valve cover, which goes to your head, which has oil and oil passages in it, which will drain into your oil pan and run through your whole engine. if you started the car, it already went through everything. my suggestion would be to change the oil with a cheap regular oil drive for a day and then change it regularly with the synthetic or whatever.
well thats good to know, thank goodness, I dont really have the tools to change my whole oil by myself, would it hurt to do one oil change right to what I am going to keep? also I want to redo the seafoam but through the correct vacuum hose next time, I wont be putting it in my oil again. Also this is a 1999 Dodge Grand Caravan, but its the same as a town and country and a couple other vans that were owned somehow by Chrysler. btw, that isnt a pic of my engine, just from the internet, I have teh 3.3 liter version, but its setup the same as this one
Pioneer 4300DVD
sorry to double post, but I also changed out my blower motor resistor because my controls stopped working except for high, and the old one was broke and corroded, but the only thing that annoys me is when I put the setting to off completely it stays on the lowest setting still pushing a little air out. It used to go completely off, and now I can hit recycle and activate it when its on the off setting. So pretty much its not turning off completely and I was wondering if you had any idea why. When I looked at the connector that hooked to the old motor blower resistor it had one that was kind of melted and I am wondering if that is causing it to have an issue, but if it wasn't connecting, due to how this specific resistor setup works, it would not be able to control any of the settings. Seeing you are a mechanic, and you have a dodge, thought you might have an idea
Pioneer 4300DVD
thats something i would have to look at the vehicles specific wiring diagram to figure out but just a question. are all the pins ok on the connector that is on the car? also where did you get the new resister?
sea foam is a petroleum based product so u can drive a lil while b4 you'd have to change the oil. i put sea foam in my rides 2 days b4 i do a oil change
yea i dont no anything about the stuff. so just to answer his question, i would just change the oil once if your not worried about it. it shouldnt be that big of a deal.
This is from a 1996, which I believe is in the same series as mine, but I am not sure, as mine is a 1999
Also there was one pin on the connector that looked burned and somewhat melted, but it also had broken one of the resistor wires, so if the new one plugged in and works that means that that is not causing an issue, it just got really hot, I may have to look again tomorrow
Pioneer 4300DVD
