HIDS still don't work... the bulb comes on but just flickers but then when I hook it up on the other side it works fine... I tried 2 different ballests(one brand new) and it still does it... if I hook up the normal headlight on that side it works fine... the HID worked fine for 3-4 months then quit working(light wouldn't come on at all) so I switched the ballest to a new one and then the light came on but flickers, so I ordered a new bulb and it came today but still does the same thing. But I can hook but the bulbs up on the other side and they work fine... any ideas?
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
are you using a relay??? if not you need to get the relay harness and wire it in...
Worked fine without one for 4 months... still does on one side. And they are only 35w so I don't really need one.
Edited by LoudNLow931
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
well i would get one.... i just bought a 35w kit and it comes with the relay... if i didnt need it then why would it come with one. also your battery might be getting old and may not have enough amps to run everything...
check the voltage coming out of the oem headlight harness.
try powering them up with a straight lead from the battery.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
just cause you have new batts doesnt mean you have full voltage coming through the leads..
:drinks: there could be a problem in the switch or in the harness.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
agreed ^^ plus, did you just do the batteries and then the lights stopped working, thats a clue that you probably messed something up. check your grounds and stuff...
