Don't just use a sheet metal screw if you're grounding it to a piece of sheet metal. Get to a spot where you can get on the underside and use a nut and bolt and sand down the whole area to remove all the paint. That's about the best you can do on a unibody car without running a ground to the front.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
You can do that, but I have a unibody car and I grounded to my rear deck with just a screw and it was fine for my olddd kicker 750.1
2006 Nissan Z Track.
My Feedback Thread
Finally fixed my problem it was a major voltage issue, i never noticed but the positive terminal on my battery had a layer of corrosion over it so i sanded it down and now i the voltage i need to power the subs, and everything is now working perfectly!
Current Setup: 90' Lumina (My Hoopty)
(2)15 inch Phantom Woofers
(1)3000-watt amp. 1500w RMS
-120 amp alt.
-JVC Deck.
-JVC 4x6's and 6x9's.
-Dual Battery powered.
-All 0 Gauge.
-Big 3 Soon2come.
sweet, thats good to hear ur problems fixed!
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
  • Who's Online   0 Members, 0 Anonymous, 482 Guests (See full list)
