MACnonsence6 Posted March 8, 2011 Report Posted March 8, 2011 say i had 2 dv1 subs could i wire each coul in parallel so id have 2 .5 subs then wire the 2 subs together in series to get a 1ohm load I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
TeamHT Posted March 8, 2011 Report Posted March 8, 2011 Confusing post is confusing Tell me...does this smell like chloroform to you?
Guest Posted March 8, 2011 Report Posted March 8, 2011 only thing i understood was 2, .5, series, and 1 ohm. from this, i assume 2 dv1 means 2 dvc 1 ohm woofers. if so, wire it like this
korey_hofer Posted March 8, 2011 Report Posted March 8, 2011 http://www.rockfordfosgate.com/rftech/woofer_wizard.asp previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
bumonskateboard6 Posted March 8, 2011 Report Posted March 8, 2011 You want 2.5 subs? Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
MACnonsence6 Posted March 8, 2011 Author Report Posted March 8, 2011 meaning 2 subs wired down to .5 own i didnt know if you could do parallel then series thanks guys I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
