sup guys well i just put in a brand new system from rf about 2 weeks ago and from day 1 its been cutting out. As soon as i want to turn it up it would cutout or sometimes it doesn't even hit the bass note and then it comes back on. When the sub cuts out the amp light is still on so is it possible that the sub is cutting out and not the amp ? I have a t1 12 on a rf prime 1000D 1000w at 2ohms sub is rated at 800rms the new 2010 model for t1s. My friend just fixed the ground all the wires have terminals and are in perfect condition (0gauge wire)any help would be appreciated ! and yes i have got the volt meter out and it has read 2ohms on the sub and amp and the amp drops down to 11 volts at lower frequencies but stays at 13 at higher frequencies
Vehicle:2002 Toyota sequoia limited edition
Subwoofer:American bass xfl 12soon to be vfl comp
Amp:2American bass phantom 4ks 4000rms (using one fornow)
Headunit:Alpine cda 105
TL scre:141.75 at 35hz going to try to get it to a 45 with the new build!
My youtube channel !
Team extreme amperage
My facebook !
sounds like back ground.
Yes i mean bad
Edited by Go-N-Def
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
where you grounded to?
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
we thought it was bad to but we just re did it. Its perfect now we got it brand new terminals and we thought it would fix it but i guess not lol
My facebook !
edit: frame t
Edited by bigmacfreak32903
My facebook !
maybe a long shot but back in the day i had the same prob ha and even an older RF sub, but nothing to do with brand. but my prob i found was the terminal on the box somehow got a few stray strand of speaker wire touching the pos and neg together. cleaned all that BS up and away i went. all was good. but like others think id say ground maybe, have a pic of the grounding point?
hmm well the type r i had before to also had the same problem is it possible that subs can cutout from getting to much power ? but ya i can take a pic of the ground tomorrow its dark right now
My facebook !
if the sub cuts out from too much power you wopuld of seen and smelled that magic smoke lol but if you had the prob before with a dif setup but same wiring id say its the wiring, somewhere.i know you know your at the right place here to figure it out :drinks:
man and im guessing you won that RF thing? if so congrats i didnt even know
Edited by cracker
lol ya i had wiring issues before when i had 4 gauge my idiot dad soldered 2 different power wires together and it was building resistance which made my old amp drop down to 9 volts lmao so thats when i purchased 0 gauge i was running the soundstream amp and it never cut out again. Then when i got the rf amp it started cutting out wich is weird as shit lol
My facebook !
  • Who's Online   1 Member, 0 Anonymous, 529 Guests (See full list)
