Anyone know about bicycles?
whats up?
Got a diamond back joker and I'm having this issue with the crank where if you put the right arm forward it tightens the chain and when the left arm is forward the chain is loose as hell.
It's a 3 piece crank, I know a bit about fixing bikes but not a lot.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
R.I.P!
(Nov-29-2009)
92 explorer
current build
Is the rear wheel in straight? And or are the bottom bracket cups (bearings) loose?
Try those and let me know how that works... As well as how drastic is the difference?
I hate long signatures....
...what the fuck is wrong wiht you you fucking fuckity fuck fuck head...
Mtnbikecrazy55 Feedback
I can make the rear wheel 100% straight but I can't tighten the chain tight because of this issue. I regreased everything when I got the bike except for the rear axle, I had that replaced and I also had the rear cog or freewheel replaced.
It's a very big difference in tension with the right arm forward.
no idea how this could happen but it sounds like your crank is off center... check it out.
Live life to the full... Then TURN THAT BITCH UP!
What do you mean by off center? I took a paint marker and marked spots along the bike and the crank lined up where ever I put the pedals, :/
