XS Power
Oh no....Please make your way around the forums and read a lot and learn before you go attempting 2 BTL's of 7k if you don't know about batteries. Also 12v batteries charge at 14v, 14v batteries charge at 16v, 16v batteries charge at 18+ volts.
soo...
whould do any harm to replace 12V batters for a 14V battery??
Yes because your alternator would not charge them and would slowly kill them.
and if i only add a 2. battery??
would that help to impromve my sistem voltage??
Adding a second battery will help your voltage stay closer to 14.4 if you're having voltage drop.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
I will just throw this in the mix, what voltage does meade charge his tahoe at? like 15.8 on 12 volt batts and he doesn't use a step down, his alts cold put out 16.6 and his electrical is fine.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Alright so you guys are saying get dual alternators and have the 16 volt alternator for the bats in the back and the stock alternator for the car its self? and if i do get 16 volt bats i need a alternator that is 18 volts? right?
off topic...
would a 160amp stock alternator be enough for 1200wRMS??
1200watts/ 14.4volts/.7*.6= 77amps
In the equation, .7 is for efficiency and .6 is because you're probably playing music
The car uses about 50 amperes, so 77A+50A= 127A. The alt is 160A, so you should be good. That's just an estimate though.
Keep in mind that the alt is supposed to put out power at ~1700RPMs and up, and puts out less power at idle
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
what does your amp do at 14 volts? you sure its not gonna be enough for the FIs. and if you wanna run the 16 volt setup youll need a 16 volt alt and 14 volt batteries. but also you WILL NEED a 14 volt alt for your cars electricals.
2000 tahoe
orion hcca 15.4
kicker zx2500
2 JL 300/4s
infinity and kicker mids/highs
KHC1400 in back, stock upfront
dont ask about my HU
clarion EQ
kicker/fosgate rcas
off topic...
....its a 2.0 diesel car(with dual bracket mounting on demand) which puts the max amperage at 1600rpms
and it idle at 800rpm...
Edited by gally
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
so i can do 18 volts in my jeep safely then? on the voltage gauge it has a red mark at 19v
No
Evo X build log
but he says himself not to do as he does.
You clearly don't understand where he was going with that example. Think about it for a few seconds...
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 1349 Guests (See full list)
