I was thinking of wiring it to the back of the deck would that be a good idea or no?
thats not where you need to monitor the voltage
the amplifier is where you should wire it too
because if your voltage starts dropping you wanna be able to turn it down before the amp gets to a voltage its not gunna like
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
What gauge does the wire have to be from the meter to the amp?
I used 22 ga for mine, voltage is pretty accurate. As the others have said ... Wire it to the amp or last battery before amp.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i use remote wire from knukonceptz witch is 18 gauge
So as far as the green wire do I just tape it and leave it hanging?
i would tape it up just to be on the safe side
could you get a link to the voltmeter? maybe i can tell you what the green is for if i see it
http://cgi.ebay.com/DC-0-100V-Red-3-LED-Digital-Volt-Meter-Voltmeter-Panel-/330541034039?pt=LH_DefaultDomain_0&hash=item4cf5c7ea37#ht_5079wt_932
The only wire i have connected to my amp is the power wire. For the turn on i just spliced it into my head unit turn on, and for my ground i just grounded to the strut tower of my car. For me, this saved a lot of wire, plus there are 2 less wires at my amp (always a good thing!)
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
