jconnway Posted March 15, 2011 Report Posted March 15, 2011 So what do you think about this I'm running about 3k watts total in a 2007 Honda Accord. I'll be charging with a 220 Amp Mechman Alt. I want to (obviously) replace the stock battery under the hood. Given those parameters, whats the recommended XSPOWER battery? I'm sure someone has a similar setup Quote Full Pioneer Build 4 Per Door - Front Door Build Up
08tahoe Posted March 16, 2011 Report Posted March 16, 2011 I think the recomemded is a d5100r but I just put a d3400 in mine last night, I just had to cut the plastic tray that holds the battery a little. I took out a yellow top optima d34/78 that fit perfect in there to put the xs power d3400 in. But my car is a 4cylinder if you have a 6cylinder it might be different. I also have a d3100 for the trunk and imma put that in asap. Right now I'm running only 1500rms for my subs and 600rms for my 6x9s and 6.5s. When I'm done imma be running 3000rms also cause I plan on putting in 2 jl audio hd1200/1 when they come out and my jl hd600/4, and I got a dc power 180hp alt. I just plan on running those 2 batteries but you never know one day I might put another d3100 in the trunk Quote
Nathan @ XSpower Posted March 16, 2011 Report Posted March 16, 2011 ^^^^ That would work great for you. D5100R is the stock replacement battery for your vehicle. You can run a smaller battery in the back if you want, but the D3100 would give you a ton of extra reserve if you upgraded in the future. Quote
