dzld231 Posted March 19, 2011 Report Posted March 19, 2011 Going to build my box in the next week. Looking for the easiest way to do terminals thru the back of my box. Was going to use a bolt thru the back, but I dont have rings on the end of my wire. What is the easiest/best way to make terminals?
thecityxignites Posted March 19, 2011 Report Posted March 19, 2011 use bolts and just go to your local audio store and pick up a box of ring terminals for your speaker wire. 2001 chevy cavalier Rebuild in progress what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2. well...as i see the level 6 is compared to a lamborghini.....but a corvette? i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
kickass audio Posted March 19, 2011 Report Posted March 19, 2011 You could do a few things... 1.) Go to radioshit (i can say that since i used to work there lol) and get their higher end speaker connection terminals and put them on the side, back, or wherever you want to on your box and then run them but i dont really recommend this for higher power setups. 2.) Get a drill bit that is the exact size of your wire you plan to use and drill it through the box or something and then run the wire through it. I did this to my box i had my solox 12 in and i had 8ga wire for the speaker wire and i used a smaller bit (dont remember the size) but i drilled that through the box and then put a little bit of hand-soap on the wire to help push it through the hole and it was a very tight fit and didnt make any noise when you hit the bass. 3,) Go ghetto and if you have a port you can run them along the side/corner of your box and use wire clips to hold them down to prevent you from hearing them slap inside the box and take it out of the port but that looks like crap if you ask me. 4.) GO WIRELESS!!! jk lmfao. edit: forgot to mention that you can just use bolts. I got bolts for my SMD and the wire terminals i am going to run and have it setup like meade has where the terminals are each getting their own ring terminal on the inside of the box and then i will run them to the bolt on the box then have another little length of 8ga wire on the outside of the box that will connect from the amp to the bolts and i can adjust the impedance however i want to from outside the box to prevent stripping the speaker bolts i plan to use and the smd weighs a shit ton so i dont feel like taking that in and out a lot. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
dzld231 Posted March 19, 2011 Author Report Posted March 19, 2011 Yea, I dont want to run regular teminal connect cuz I heard they leak air around them... So I was thinking either getting ring terminals or doing the wire thru the box... Looking for suggestions and opinions.
TIG Posted March 19, 2011 Report Posted March 19, 2011 Use bolts and some rubber washers Since were all having a moment of truth. I hate country too.. I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick.
blownengine Posted March 19, 2011 Report Posted March 19, 2011 Home Depot and such will have small packs of ring terminals. They come in packs of 8 I think. And nearly every size you can think of. 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
kickass audio Posted March 19, 2011 Report Posted March 19, 2011 Yea thats where i got my ring terminals at was home depot. IDK about the quality of them since you can bend them very easily since the metal is soft on the rings but it does conduct very well for what i need it to do. I believe mine was a 6 or 8 pack of 8-4 gauge ring terminals. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
