idk maybe smooth the holes, or just the diameter alil bigger if you like, the only thing i dont like is that the holes for the screws like the ring of rubber doesnt match up with the baskets screw holes
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
the whole deal behind this was, the hole size needed to fit the DC inverted, is just bigger than the screw holes, where, the screws might almost split the mdf and move inward towards the sub and not hold it down, if you understand what im saying.
got ninja'd ^^^^, idk i would have to see what it looked like, i know that one guy with the 4 or 6 XLs(lime greenish) or something did it like that.
Edited by I like kicker
make a MDF ring the like 1.5" wide from inside edge to outside edge. Mountr you sub in this ring then moung the ring on top of the box, having your baffle hole plenty big enough for the surround to go though, yet still having plenty of wood to screw to, might loook a little ghetto but it will work.
i can make a sketchup if your confused.
yeah, if you mount them from the inside it will be like they were mounted normally.
how would you get them out though? with my idea you could still the the sub in and out of the box...
you could even double baffle, mount the sub to the outer baffle on the inside make the inside baffle holes like 13" for a 12" sub then have the whole second baffle removable to get the subs in and out...
i like that idea, basically, an upside down flush mount. probably end up using bolts for added strength if i did that.
  • Who's Online   0 Members, 0 Anonymous, 905 Guests (See full list)
