Okay i have a 2-channel 1500 watt rms amp, that is 2ohm stable and I have it hooked up to (2) 15-inch DVC 4Ohm Subs wired at a 4Ohm load. My question to you guys is that if I run it in parallel to bring it down to 2Ohms would that be better cause I'm only getting around 450 watts on each channel at 4Ohms, but my friend today said that they could only be wired up at 4Ohms or 1Ohm, but i think he is referring to a mono-block amp and not a 2channel.. Any Help peeps?
Current Setup: 90' Lumina (My Hoopty)
(2)15 inch Phantom Woofers
(1)3000-watt amp. 1500w RMS
-120 amp alt.
-JVC Deck.
-JVC 4x6's and 6x9's.
-Dual Battery powered.
-All 0 Gauge.
-Big 3 Soon2come.
can you bridge the amp?
Edit: and by 2ohm stable, do you mean each channel is 2ohm stable?
Edited by Lost Legacy
Honda Accord SirT + Mad sounds = Awesomeness
VTEC go BRAAAAAPPPP :P
http://www.stevemeadedesigns.com/board/topic/141261-99-accord-sirt-sq-build/
Alright well i never done the big 3 so i see in my vision my truck on fire...
Im pretty sure each channel is stable at 2ohms for 1500 watts on each channel, and bridging the amp brings it to peak power of 3000 watts on one channel.
-120 amp alt.
-JVC Deck.
-All 0 Gauge.
-Big 3 Soon2come.
if you do 2 ohms your amp will require 50% more power if i recall right
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Indeed it requires 50% more power.
-120 amp alt.
-JVC Deck.
-All 0 Gauge.
-Big 3 Soon2come.
i personally would bridge then, if your subs could take 1500W each
if its a 2 chan at 1500rms, than it would most likely be doing 750 per chan
plus 2 dvc 4 ohm subs wired in parallel would present a 1 ohm load not a 2 ohm and if wired in series gives it 4 ohm load, is there another way you will wire it
I need to know if i can wire each channel in parallel instead of bridging, will it cause any difference?
-120 amp alt.
-JVC Deck.
-All 0 Gauge.
-Big 3 Soon2come.
Okay ill add some clarity with a diagram of how its hooked up.. This is how its hooked up now.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_2-ohm_2ch.jpg
I'm wanting to hook it up this way, just need to know if its correct, and wont cause any harm.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_2ch.jpg
Can i even wire two 4ohm subs to 2ohms? cause it requires more current 50% more, and its recommended to be more efficient i feel as if not there not really hitting to there potential being wired at 4ohms
Edited by ClarkB
-120 amp alt.
-JVC Deck.
-All 0 Gauge.
-Big 3 Soon2come.
lol, and? What does that matter?
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
  • Who's Online   0 Members, 0 Anonymous, 1530 Guests (See full list)
