ill be buying a dodge durango in the next month or so and "officially" start this build log. but before i started working on the system i was going to throw up some sketchup ideas i had for sub boxes and get advice from some people. im planning on using two 12" fusion powerplant subs powered by 2 fusion 1,000W amps, fusion head unit, fusion powerplant components and coaxials all around which will be powered by fusion 1,200W 4ch amp. i chose fusion cuz i love the way they look and the lime green on them will go with my black/white/limegreen theme ill have for my durango. and they seem like they are built really good too. ill keep you all up to date and let you know when i actually get the durango and start the build.
the huge hole in the front will be covered with plexiglass from the inside, and the bluish bottom is going to be mirrored lexan. box will also have green LED's
top view of box. port will be tuned to 32hz and box will be 5 cubic feet. 2.5' for each sub, to fusions specs.
I would be careful because there rated 500 RMS..
yeah, im kinda worried about that but the max is 1200 and im not building it for competition so i wont be abusing them too much. but yeah, i might have to watch them for a while.
What series of their amp are you looking at? Because the only 1200 I see is a 4 channel.
im going to get two preloaded enclosures that comes with the 12" and a 1000W powerplant amp. its the same sub thats on the fusion website and its actually cheeper getting them this way. im probably not going to use the boxes for long and ill get bigger gauge wire for power. here is the link
http://www.vminnovations.com/product_2339/FUSION-12-Inch-Enclosed-Subwoofer-with-1000W-Amplifier-and-Sub-Kit.html
:drink40::popcorn:
i havent seen anybody use fusion stuff in a while... do there amps put out rated?
BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry1565972
98 Ford F-150
Truck:
37" superswamper tsl radials
16" ion alloy wheels
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
2 18" Sundown Nightshaed
Aq3500
Custom Fiberglass box
fosgate T1 6x8 Coxials
bass inferno 2000 watt 4 channel
2 XS power d3100's
0 Gauge
they are overrated.
(UNDER CONSTRUCTION)
Kenwood KIV-700 headunit
2 18" sundown Z.v3s
13.5^3 wall tuned @ 28hz
SAZ-3500
DC power 270amp alt
JL c2 650
AP600.4
XS 1200 under the hood
XS 3100 in the trunk
1/0 gauge
big 3
25^2ft audio technix
^^ c-fuzzy ur an idiot, my 15" soround is waay bigger cuz its a tall sorround, on top of that I HAVE A BIGGER MOTOR... oh yeah and fuck u suck my dick i got your hoes!
anywhere they want to. They cant hear anyone telling them otherwise. just because its bigger doesnt make it any different. they just piss people off faster and farther away.
i would assume so, on the specs it looks like when they are wired to 1 Ohm they should put out full power or close. but i will see when i get the amps.
