D-train-13k Posted March 27, 2011 Report Share Posted March 27, 2011 its still in the rough phase but hopefully the 6in pvc will blow some stuff around (: amp is going to be an AQ 2200D wired at .5ohm its going into my 2000 F150 extended cab im thinking about having cushions mounted on either side of the ports so the girls can sit in the back and wrapping it in a carbon fiber vinyl. as well as redoing the interior of my truck. any thoughts? The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/ Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 27, 2011 Report Share Posted March 27, 2011 specs please R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
D-train-13k Posted March 27, 2011 Author Report Share Posted March 27, 2011 specs please 4 cubes ported 2 cubes sealed. tuning at about 52Hz (i dont remember exactly) somewhere around there. i dont have the sheet with me you were talking about the box specs correct? The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/ Link to comment Share on other sites More sharing options...
