XS Power
would it be possible to fit two d3100's under the hood in a 2002 chevy silverado 4.8 v8. or would i have to mount one in the cab. im looking at 1 d3100 as a main and partially for the system and the second d3100 for the system only
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
I think the D3400s would fit better under the hood
I have two under the hood of my 97 burban
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
they can both fit under the hood but you will have to modify the battery tray meade has 2 under the hood of his tahoe and its the same body style
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Pretty sure he only has 1
1 d3100 will fit with some work
would the d3400's be able to handle 4000 watts with 1 as a primary batt?.
your right i forgot that he had the intake on the other side
op if you truck has a battery tray on the passenger side 2 will fit but again it will take some work i know when i had my 99 tahoe it had 2 battery trays but i only had one battery :pardon:
yeah thats why i was wondering it does have the plate for two batts id just have to modify the plate and the wireing hopefully. if not ill run one d3100 and 1 d3400
Do you have an upgraded alt?
planning on upgrading to a 280 amp dc. or i might possibly do a dual alt bracket. and i just found out my truck dosnt have the dual battery pans. i was thinking of my dads avalanche apparently
Edited by bass_stalker
D3400=2500watts as primary and 4000watts as secondary
