kogwanted Posted March 31, 2011 Report Posted March 31, 2011 Ok so my little brother wants subs he got two type r 1242d well he don't have an amp so I gave him my old Sony xplod "1000watt" 2/1 I know for nOw till he gets money to get some thing else well I only bridge my stuff I'm a noob on this stuff I hooked it up bridged u barely turn it up and of course it goes into protect so can I just run each sub off of one set of +n - cuz one set on the amp has btl over two of the terminals o don't know what that means can I hook a sub to that and another to the other set like I said I no it's shitty but he wants some baby bumps till he can get a decent amp thanks
Tarball Posted April 1, 2011 Report Posted April 1, 2011 Ok so my little brother wants subs he got two type r 1242d well he don't have an amp so I gave him my old Sony xplod "1000watt" 2/1 I know for nOw till he gets money to get some thing else well I only bridge my stuff I'm a noob on this stuff I hooked it up bridged u barely turn it up and of course it goes into protect so can I just run each sub off of one set of +n - cuz one set on the amp has btl over two of the terminals o don't know what that means can I hook a sub to that and another to the other set like I said I no it's shitty but he wants some baby bumps till he can get a decent amp thanks uhhhmm You should start with more sentences and maybe some bullet points. I can't believe I just read that whole thing with one mental breath! CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
C.Sanchez.A Posted April 1, 2011 Report Posted April 1, 2011 He want's to hook up two Alpine Trype Rs (1242d) to a Sony Xplod "1000watt". The question should be... What model is the amp. Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel
Tarball Posted April 1, 2011 Report Posted April 1, 2011 Also, if I follow this correctly and if i've got the specs right: Subz: 2 12s dual 4 ohm Amp: (based on SON9-XM1652Z) 400 X 1 @ 4 ohm or 200 X 2 @ 2 ohm Wire each 12 in parellel to one side of the amp. each sub will get 200w (ish) (if your lucky). If the amp is just stuck in protect mode you may need another... in short, you may have it all bridge lower than the amp can handle. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
