KnockinthaStreetzof608 Posted April 3, 2011 Report Share Posted April 3, 2011 hey i have a question, i downloaded some music videos to my sd card and it is a avi file but it still wont play all it says, "video frame rate no support" any idea on whats the issue? CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
ShadowWolf9 Posted April 3, 2011 Report Share Posted April 3, 2011 What type of sd card are you using exactly? What class is it? 2009 Honda Accord EX-L System in the works: Pioneer AVH-3200DVD (check) Hertz Mille MLK165 (check) SAX-125.2 (check) AA Havoc 12" Ported (check) SAZ-1500D (check) 1/0awg Knu Kolossus Flex (check) XS Power D3400 (check) Stock 120amp Alternator SS Damplifier Pro (check) Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted April 3, 2011 Author Report Share Posted April 3, 2011 What type of sd card are you using exactly? What class is it? its a sandisk 8gb sdhc card i as the lady at walmart for a class two though, but im not sureif this is the correct one gimme me a sec and look up the card online CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted April 3, 2011 Author Report Share Posted April 3, 2011 my SD card CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
04SDExplorer Posted April 3, 2011 Report Share Posted April 3, 2011 needs to be in divx format, i was having the same problem with mine. 2004 Explorer Limited 24" Lexani "pyros" wrapped in 255/30/24 pirelli's 270 Amp MechMan Alt. (2)Stinger SPP-2150's (2)Sundown NightShade 15's IA 40.1 Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted April 3, 2011 Author Report Share Posted April 3, 2011 but i was told from several other ppl that it was perfectly fine to use in a avi format? so was i incorrect? CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
04SDExplorer Posted April 3, 2011 Report Share Posted April 3, 2011 I tried all different formats, and never could get them to play. I read somewhere it had to be divx, so i got the divx plus converter and converted all the files, and problem solved. 2004 Explorer Limited 24" Lexani "pyros" wrapped in 255/30/24 pirelli's 270 Amp MechMan Alt. (2)Stinger SPP-2150's (2)Sundown NightShade 15's IA 40.1 Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted April 3, 2011 Author Report Share Posted April 3, 2011 yup i just donwloaded now maybe you have the same program what setting you put urs in? mobile home theater ect....??? CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
04SDExplorer Posted April 3, 2011 Report Share Posted April 3, 2011 home theater. Tried mobile, the picture looked real blurry. The hd ones obviously won't work, i'm not sure where you get your vids from but download the best quality you can because the quality suffers a little bit after transferring. 2004 Explorer Limited 24" Lexani "pyros" wrapped in 255/30/24 pirelli's 270 Amp MechMan Alt. (2)Stinger SPP-2150's (2)Sundown NightShade 15's IA 40.1 Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted April 3, 2011 Author Report Share Posted April 3, 2011 i got it from a youtube donwload videos site maybe pm me if can reccomd me a good site, i know here on the forum speaking about this get threads locked CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
