How do you do it without a slave output and a processor? is there a way?
Also for the gain knobs can you use two seperate ones and it be alright?
fyi i am planning on running one aq1200 and later add annother aq1200 so would the two gain knobs work together or how would i get a way to control both amps with one knob?
Edited by Winn
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
Hook the knob up to the master amp.
There's a switch on each amp. Master output/Slave input. Select the master output for the master amp and the slave input for the slave amp.
Run one set of RCA's to the master amp. Run a rca cable from the master to the slave amp.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
you can control them both with one knob when you strap the amps together
but how would you strap them together?
What's the voice coil configuration of your subs?
Well two 15s going on first amp both D4
and the other two 15s is going on the second amp is also D4
Example of how I have my two Dual 2 ohm subs wired to strapped AQ 2200's.
Sub one: positive of coil 1 to negative of coil 2. Negative of coil 1 to positive of slave amp. Positive of coil 2 to positive of master amp.
Sub two: positive of coil 1 to negative of coil 2. Negative of coil 1 to second positive terminal of slave amp. Positive of coil 2 to second positive of master amp.
Each AQ amp has two positive terminals and two negative terminals.
First negative terminal of master amp to first negative terminal of slave amp.
Second negative terminal of master amp to second negative terminal of slave amp.
Bass knob hooked up to Master.
RCA's from HeadUnit to Master. Master amp switched to master output. Slave amp switched to slave input. Rca cable connecting the master to the slave.
That sorta made sense but i am going to have two subs per amp???
  • Who's Online   0 Members, 0 Anonymous, 1743 Guests (See full list)
