using diodes to step up voltage
@loudcivic im still trying to figure it out which wire to use im guessing its the brown wire. but i rather be sure and not cut the grey wire for no reason. i found a diagram for my alternator (ad244)
la negra if you look at the pcm at the top it says field duty cycle signal and thats the gray wire. that should be your sense wire. ami needs to come back in and confirn since he was talking about the alt being in full field mode.
imnotloud that is probably your sense wire with no voltage but i cant confirm it.
2015 silverado crew cab
nothing atm but soon...
any help on a 99 4.0 V6 soch explorer ?? :(
fecupe: look back at post 154. your sense wire loops back into the alternator. to me that would be the wire i would try to put the diode in
fecupe i need a picture of your alternator wiring. i believe this is the right one but not 100 percent sure. if it is then it should be easy
white/black wire is your sense wire and it just loops back into the alt
the wire that is inside the yellow is the sense wire for a ford 3g alternator. i believe your alternator is the same and the diode should go between the 3 wire harness and were it plugs back into the alternator. this one is different so im not totally sure how the ford alternators work. remember your doing this mod at your own risk of screwing up your car
let me know and take a pic if you can. im just tryin to help if i can. it may work it may not
also fecupe can you take a picture of your alternator for me
Man, i didn´t see this posts before, thanks a lot!! Dont worry, i know it´s on my own risk, well i changed my alternator for a mechman 270A , my stock alt it´s on my brother´s home, i´m gonna ask him the pics and i´ll post them here before doing anything, i´ll post them in a while, thanks a lot so far for your help hommie...
if your plugs and the wires for the alt are the same as your stock alt wires you could try and put the stock alt back on to test this so you dont screw up your mechman alt if something did go wrong. then put the mechman back in if you were successful with the mod and voltage is good
i have a 99explorer with the 4.0 sohc and its the yellow wire on mine.. there is 2wires 1-green 1-yellow on my plug,, hope that helps u out
