Chevyboy95's Ext Cab Build (New Vid pg6)
Great build! Looks very clean and promising for sure.
How did you like the 2 AQ's strapped with the 2 15s? I'm still trying to understand how they were wired because I'm thinking of doing something similar with the AQ1200. Is it wired to 2 Ohm on the amp and bridged to 1 ohm for each sub giving 1200W to each?
the 15s were Dual 2s, so i wired each sub in series to get 4 ohms at each sub. Then i wired them in parallel to the AQs (positive leads to master positives, negative leads to slave positive, the negatives on the amps are wired together like from amp to amp). I can draw i diagram if you need one.
For anyone who cares... :peepwall: i did some more work.
Everything is hooked up and playing... except for the bass......
I can tell just from the 2 minutes of playing the O2 F150 amp that is a lot more powerful than the Mb Quart DSC450 and sounds crisper. Already loving it.
I really like the finish on the box now and that port is sick! How many cubes and what are you tuned to?
See a lot of builds waiting on DC to deliver but good things come to those who wait!
:drinks:
2007 Pacifica
:drinks:
5.7 cubes, 15.7sq in per cube, 36hz.
its at the point where soon as i get the sub i can drop it in and slam.
The way I read that made me think of this
Can't wait to see it, bro. :popcorn:
2007 Pacifica
