My battery and alternator is stock. I am going to run an AQ1200 and an amp for mids and highs (undecided on the brand, putting out 400 RMS range). Is it necessary to use an extra battery? Do i need to?
Pioneer 6300ub
Rockford Prime 6.5's
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
1.4 Cubic Foot Enclosure Tuned to 34 hz
Stinger 4 Gauge Wires
not needed for that power but with electrical its always best to have more than not enough at the very least you could upgrade the battery under the hood
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
I think it depends..if you turn up your system and the lights dim, I reccomend atleast another battery.some cars electrical is better then others when stock..I think even if your lights are not dimming and your electrical can handle your setup, it is still a good think to upgrade it
how many amps is your alternator? i highly doubt you will need another battery, but i'd recommend doing the big 3.
I'm just gonna say everything is stock on a 2000 toyota solara. I bought pioneer 6.5s and 6x9s and largely regret it. By upgrading the big 3, are u talking about going to 0 gauge wires? Because i was trying to steer clear of that because it will draw so much power from my battery.
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
your alt is 8 0 amps. you SHOULD be fine with just the big 3 done. and i dont understand why you think adding 0 gauge to your existing electrical system will make the battery draw more power. alls it allows your car to do is make its charging system more efficient so you will have less voltage drop
Edited by Kranny
The big 3 are your wires under the hood..
bat wires and alt wire should be atleast 2ga..
I've gotn away for yrs on a stock grand prix alt with an redtop bat in trunk..
Amp is a mmats dhcx2200.1
yeah but i'm going to be running 2 amps on it, i was thinking 4g wire, for both, see i'm trying to learn here because i've never wired amps before i've always had somebody else do it.
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
i have 2 amps on a stock alternator with the big 3 done and never had any problems whatsoever.
  • Who's Online   0 Members, 0 Anonymous, 1072 Guests (See full list)
