Today, I started the big 3 on my truck. I bought some 0g KnuKnoceptz KCA wire.
20ft and gold terminals from Darvex
Hooked up the positive to the alternator...
And the ground to the body. Is this a good spot?
Here's the grounds hooked to the battery. The open one is for the engine block to negative terminal.
My questions are:
1. Is my ground to the body okay? Or should I move it?
2. Will any bolt on the engine block do or should I find a certain one?
Thanks in advance, guys. Y'all are a great help!
Float mounted IPad Mini playing through Bluetooth
IStreamer for Iphone or Ipad
Rockford Fosgate 3Sixty.3
RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors
Two Rockford T600-4's for the components
Blowthrough with two Sundown SA-8's
RF T1500-bd's for the subs
8000k H.I.D.'s in headlights and fogs
Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift)
17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's
Undercover Bedcover
Surco Roof Rack
Five Hella Lights on front bumper
270A Mechman Alternator
Two Optima Yellow Top batteries
Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
i put mine in a bench vice. i have also used 18 inch channel locks. ran them over between to pieces of metal. hammer and chizel orrr c clamp
BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry1565972
98 Ford F-150
Truck:
37" superswamper tsl radials
16" ion alloy wheels
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
2 18" Sundown Nightshaed
Aq3500
Custom Fiberglass box
fosgate T1 6x8 Coxials
bass inferno 2000 watt 4 channel
2 XS power d3100's
0 Gauge
Your ground though not ideal, will do
The strut tower or frame (if it has one) would be much better.
Yes, any bolt into the block should do.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
I don't have a strut tower, as it's a Chevy Colorado. So where do y'all suggest?
I crimped them by squeezing the shit out of them with channel locks!
Undercover Bedcover
Surco Roof Rack
Or I guess "strut tower" not strut!
Undercover Bedcover
Surco Roof Rack
So, for the frame ground, I need to find a spot that's a little stronger reinforced?
Undercover Bedcover
Surco Roof Rack
