Yea, try to find a spot on the frame in the front if you can
Some more Colorado owners need to chime in ;)
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Will do. I'll run some wires down through in the morning and hook them up that way.
Float mounted IPad Mini playing through Bluetooth
IStreamer for Iphone or Ipad
Rockford Fosgate 3Sixty.3
RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors
Two Rockford T600-4's for the components
Blowthrough with two Sundown SA-8's
RF T1500-bd's for the subs
8000k H.I.D.'s in headlights and fogs
Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift)
17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's
Undercover Bedcover
Surco Roof Rack
Five Hella Lights on front bumper
270A Mechman Alternator
Two Optima Yellow Top batteries
Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
Bump
Undercover Bedcover
Surco Roof Rack
I believe I'm gonna try to get that bolt right there. It's on the actual frame that goes to me bumper! Watcha think?
Undercover Bedcover
Surco Roof Rack
Got the frame ground.
And the engine block.
All connected.
Just need to upgrade my battery now. And get a voltmeter to see what voltage, I'm running at.
Undercover Bedcover
Surco Roof Rack
:good:
Thanks bro! So upgrade the battery then possibly alternator?
Undercover Bedcover
Surco Roof Rack
:good:
hells yea, also did you grind the paint off for that frame ground?
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
:good:
Yessir. I sandpaper'd it down to metal.
Undercover Bedcover
Surco Roof Rack
