JasonsKreationz Posted April 8, 2011 Report Posted April 8, 2011 I'm going to be buying speaker wire today and I wanted to see what gauge everyone things I should buy. I need to buy speaker wire for my mono sub amp and my 4ch mids/highs amp. The sub amp will be running two 12" subs at 1 ohm about 500 watts RMS each. The amp is about 12 feet from the subs. Since this is a mono amp, I'll be running only one positive and one negative from the amp to the box. Once I get it to the box, I'll split it to the two subs. So the wire will be carrying about 1000 watts RMS. I was wondering if 10 gauge would be sufficient or should I run two 8 gauge power/ground wires to them? The 4ch amp will be running two sets of components at 4 ohms at 60 watts RMS per channel. The longest run of wire will be to the front speakers which is about 15 feet away. Will 14 gauge be sufficient? Thanks guys! I only want to do this once so I figured I'd ask the experts! 05 Ram 1500 4x4 Hemi - 22x11 Fuel Hostage wrapped in 37" Nitto Mud Grappler - 3" Dual Flow Master w/ X pipe - 10" lift - Alpine 103BT Head unit - JL Audio J2-320.4 - JL Audio J2-1000.1 - (2) 12" JL Audio W3V3 - (2) sets of JL Audio components - 5% tint - 6000K HID - CAI - and more....
ISO Posted April 8, 2011 Report Posted April 8, 2011 12 gauge for the subs and 16 gauge for the mids and tweets. (this is just fine) Use 14 gauge if you can but the 16 gauge is more than enough. EDIT 10 gauge for the subs and 14 gauge for the mid & tweet amp is the largest you would need. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
ISO Posted April 8, 2011 Report Posted April 8, 2011 you are not going to gain anything by using bigger wire. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
TheyDontWantMusic Posted April 8, 2011 Report Posted April 8, 2011 depends on your subs impedance. 500watts into half an ohm is over 30amps. but 500watts into 8 ohms is less than 8 amps.
JasonsKreationz Posted April 8, 2011 Author Report Posted April 8, 2011 depends on your subs impedance. 500watts into half an ohm is over 30amps. but 500watts into 8 ohms is less than 8 amps. Subs are 2ohm. I'm running a 1000.1 JL amp at 1ohm with 2 JL W3V3-2 05 Ram 1500 4x4 Hemi - 22x11 Fuel Hostage wrapped in 37" Nitto Mud Grappler - 3" Dual Flow Master w/ X pipe - 10" lift - Alpine 103BT Head unit - JL Audio J2-320.4 - JL Audio J2-1000.1 - (2) 12" JL Audio W3V3 - (2) sets of JL Audio components - 5% tint - 6000K HID - CAI - and more....
JasonsKreationz Posted April 8, 2011 Author Report Posted April 8, 2011 you are not going to gain anything by using bigger wire. Thanks for the help! I realize that you can't gain by using wire too big, but my concern is not using big enough. I'll probably just go with 10 gauge on the subs and 14 gauge on the mids/highs. 05 Ram 1500 4x4 Hemi - 22x11 Fuel Hostage wrapped in 37" Nitto Mud Grappler - 3" Dual Flow Master w/ X pipe - 10" lift - Alpine 103BT Head unit - JL Audio J2-320.4 - JL Audio J2-1000.1 - (2) 12" JL Audio W3V3 - (2) sets of JL Audio components - 5% tint - 6000K HID - CAI - and more....
ISO Posted April 8, 2011 Report Posted April 8, 2011 you are not going to gain anything by using bigger wire. Thanks for the help! I realize that you can't gain by using wire too big, but my concern is not using big enough. I'll probably just go with 10 gauge on the subs and 14 gauge on the mids/highs. Thats what I use. its more than big enough but its still not over kill LOL. My setup is 125x4 and 1800x1. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
TheyDontWantMusic Posted April 8, 2011 Report Posted April 8, 2011 I'd run 8 gauge to the subs, its not that much more expensive than 10 gauge, and it sounds like your amp is a fair way from the subs.
Craig28 Posted April 8, 2011 Report Posted April 8, 2011 i use stinger 8 gauge TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
Craig28 Posted April 8, 2011 Report Posted April 8, 2011 I'd run 8 gauge to the subs, its not that much more expensive than 10 gauge, and it sounds like your amp is a fair way from the subs. haha at the shop in my town the lowest they go in speaker wire is 10awg but you can just buy 8awg power wire for about 3 dollars less. TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
