I installed a Metra dash kit on my 2010 Mustang with no problems, until I tried the a/c. If I turn on the a/c, fan, or heater, the radio turns off. When the fan is turned off, the radio comes back on and continues like nothing happened. Any installers out there who have installed one of these kits, please chime in here. Any ideas would be greatly appreciated. I would like to use my heater/ac and radio at the same time.
Here's the kit
Metra Mustang dash kit
Edited by OrionStang
SMD Super Seller
My Feedback Thread
By the looks of the pics, the dash kit you got has nothing to do with the wires...i'd pull everything out and double check all your wires, make sure you didn't strip any back by accident...might be grounding itself out somewhere.
im with baker on this one. sounds like you have some kind of grounding issue. i would take it out and just hold the radio and try it again to see if you have the same issue.
2015 silverado crew cab
nothing atm but soon...
I'll try it. If that is the case, do I just need to find a better ground for the deck? I spliced it into the ground wire on the factory harness.
SMD Super Seller
My Feedback Thread
Checked all the wiring again and tried what Loudcivic said. Still does the same shit. I'm thinking about running a second hotwire with an inline switch if I can't figure this out.
Click the picture to watch:
SMD Super Seller
My Feedback Thread
That dash kit is just a plug right? What did you splice into for the radio? Ground, ignition or 12V power any or all weak/lose connections or voltage below range will make the radio shut down.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Yes, just a plug. My connections are good, 12v and ground at the factory radio harness, ign off the accessory wire from the ignition. Only thing I can think is, when the fan comes on the voltage in that acc wire is going down. I need to get a new dmm lead(one broke) to check that.
SMD Super Seller
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
