im looking for a good amp that can put out 3000 watts at 2 ohms for under or about 1000 dollars. any suggestions?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
http://www.audioque.com/AQ3500D1-Amplifier_p_32.html
Or 2
http://www.audioque.com/AQ2200D-Amplifier_p_31.html
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
Or 2
you can strap two of the AQ2200ds at two ohm
or run the 3500D at .5 ohm 8) *with proper electrical
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
why at two ohm?
AQ3500D.1 is $750 brand new
x2
I'm currently looking to buy 2 AQ3500's for my build. Been researching them for a while now and they seem to be some of the best amps for the money today.
the dp 21 is dual 4 ohm if i recall so itll be wired down to 2 ohms. most of the amps i looked at were only about 2000 watts at one ohm
do you already have the sub?
you could do two AQ2200Ds strapped at two ohm, that would be $780 for both amps
i didnt order it yet. i'm gonna try to do the big three and batteries plus run all my wire before i buy the sub or the amps
i didnt order it yet. i'm gonna try to do the big three and batteries plus run all my wire before i buy the subs or the amps
does the sub come in Dual 2? if it does get the dual 2 ohm version
i think it might. it looked like it said dual 1 ohm or dual 2 ohm tho. so im guessing it was talking about dual 4 or dual 2
  • Who's Online   0 Members, 0 Anonymous, 904 Guests (See full list)
