.25 ohm stable amp?
Guest BlueberrySPL
What coils do you have to feel the need to run that low
you can run 2 plain old d1 coils at .25
um 2 one ohm coils can be ran t .5? 4 can be ran at .25
1-1=.5 + another 1-1=.5 then wire then together for .25 i think he means a pair of d1 not 2 1ohm coils
ur math is a little off 1-1=0 1/2=.5
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
hell on my powerbass's i ran my 2 apxx 15s at hmm lets see
4 subs- 2 amps
2 0.7 coils wired down to .35 per sub then wired down once again at the amp bring it down to .175 per amp and it played music haha
also was on 16 volt system
R.I.P!
(Nov-29-2009)
92 explorer
current build
my math isnt off i didnt meen subtract i ment 1ohm wired to 1ohm
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
  • Who's Online   1 Member, 0 Anonymous, 831 Guests (See full list)
