87ChevyCaprise Posted April 13, 2011 Report Posted April 13, 2011 I have a Infinity Kappa One Mono subwoofer amplifier — 800 watts RMS x 1 at 2 ohms and 2 Infinity Kappa 120.9W Kappa Series 2 Ohm or 4 Ohm Subwoofer Power Handling: Peak: 1400 watts RMS: 350 watts Please help me wire these the right way Quote
blownengine Posted April 13, 2011 Report Posted April 13, 2011 Your amp is 2 ohm stable. So you need to switch the subs to 4 ohms and wire them in parallel for a final impedence of 2 ohms. Quote 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
roger1978 Posted April 13, 2011 Report Posted April 13, 2011 i would run it positive to positve and negative to negative on the sub which will give you a 1ohm load and the run it to the amp if your amp is stable at 1ohm Quote current spl 156.9 @ 40htz usaci mod 2001-4000 155.5 at 40htz http://www.stevemeadedesigns.com/board/topic/102676-rogers-chevy/page__p__1425005__fromsearch__1#entry1425005
blownengine Posted April 13, 2011 Report Posted April 13, 2011 i would run it positive to positve and negative to negative on the sub which will give you a 1ohm load and the run it to the amp if your amp is stable at 1ohm Its not 1 ohm stable. Hence why I said wire it to 2 ohms. Quote 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
D-train-13k Posted April 13, 2011 Report Posted April 13, 2011 wire it like that. Quote The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
87ChevyCaprise Posted April 13, 2011 Author Report Posted April 13, 2011 wire it like that. the amp kicked pretty much right away! now whats wrong? lol Quote
D-train-13k Posted April 13, 2011 Report Posted April 13, 2011 what do you mean kicked? Quote The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
87ChevyCaprise Posted April 13, 2011 Author Report Posted April 13, 2011 the amp went into protect mode and then reset and came back on Quote
blownengine Posted April 13, 2011 Report Posted April 13, 2011 the amp went into protect mode and then reset and came back on So is working now or not? You just said protect but then it came back on. Quote 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
D-train-13k Posted April 13, 2011 Report Posted April 13, 2011 (edited) how did you wire the subs to your amp? you cant wire them to the two outside pos and neg terminals. Edited April 13, 2011 by D-train-13k Quote The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
