Can someone tell me how to wire my subs to my amp the right way?
I have a
Infinity Kappa One
Mono subwoofer amplifier — 800 watts RMS x 1 at 2 ohms
and
2 Infinity Kappa 120.9W
Kappa Series 2 Ohm or 4 Ohm Subwoofer
Power Handling:
Peak: 1400 watts
RMS: 350 watts
Please help me wire these the right way
Your amp is 2 ohm stable. So you need to switch the subs to 4 ohms and wire them in parallel for a final impedence of 2 ohms.
Big 3 with Yellow Top
i would run it positive to positve and negative to negative on the sub which will give you a 1ohm load and the run it to the amp if your amp is stable at 1ohm
Its not 1 ohm stable. Hence why I said wire it to 2 ohms.
wire it like that.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
what do you mean kicked?
the amp went into protect mode and then reset and came back on
So is working now or not? You just said protect but then it came back on.
how did you wire the subs to your amp? you cant wire them to the two outside pos and neg terminals.
Edited by D-train-13k
  • Who's Online   1 Member, 0 Anonymous, 1641 Guests (See full list)
