IH8PunkRok Posted April 13, 2011 Report Posted April 13, 2011 for example that area in the center is empty and essentially a port extension. would i calculate all the way up to the sub? explain a bit if you understand the issue please Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
speedball1978 Posted April 13, 2011 Report Posted April 13, 2011 that looks like a bandpass, are you trying to accomplish a 4th or 6th order? Quote
IH8PunkRok Posted April 13, 2011 Author Report Posted April 13, 2011 neither im just trying to do a standard ported box but this configuration is the only way i can fit that amount of subs Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
speedball1978 Posted April 13, 2011 Report Posted April 13, 2011 and what size subs, how much power you running.. how much space do you have available.. Quote
nCOMP1337 Posted April 13, 2011 Report Posted April 13, 2011 id talk to sanitarium, he created a calculator to calculate that sort of box i believe for when he remade his blowthrough Quote
IH8PunkRok Posted April 13, 2011 Author Report Posted April 13, 2011 (edited) mustang trunk max dimensions being 14h x 34w x 24d 8" subs (6 of them) and 2k of power and i have messaged Sani, I just like learning Edited April 13, 2011 by IH8PunkRok Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
speedball1978 Posted April 13, 2011 Report Posted April 13, 2011 yea i think he did either 6 12's or 6 15's id talk to sanitarium, he created a calculator to calculate that sort of box i believe for when he remade his blowthrough Quote
speedball1978 Posted April 13, 2011 Report Posted April 13, 2011 ok then do a 4th order with a 3:1 ratio Quote
inm Posted April 13, 2011 Report Posted April 13, 2011 ok then do a 4th order with a 3:1 ratio It's not a bandpass. It's a ported blow through. The line on the front must be throwing you off. That line is marking the perimeter of the box, there's not piece of wood there. Or, that's what I'm getting from this. Quote On 2/28/2013 at 2:52 PM, Chaise said: "Now spread your butt cheeks so I can zap your asshole."
