CWorthington Posted April 15, 2011 Report Posted April 15, 2011 So i just picked up this Diamond Audio D5600.2 amp. I have it bridged and mono for 600 watts rms. Anyways it says to use a maximum of 90 amp fuse. My only problem is, i cannot find one. What should i do? I just blew the 80 yesterday pretty fast, not sure why.
TheyDontWantMusic Posted April 15, 2011 Report Posted April 15, 2011 are you running it below 2ohm per channel? are you running 4 gauge cable? the fuse at the front near the battery can be upto 100amp, it won't be an issue. the amplifier has 90amp worth of inbuilt fuses doesn't it?
dereileak Posted April 15, 2011 Report Posted April 15, 2011 So i just picked up this Diamond Audio D5600.2 amp. I have it bridged and mono for 600 watts rms. Anyways it says to use a maximum of 90 amp fuse. My only problem is, i cannot find one. What should i do? I just blew the 80 yesterday pretty fast, not sure why. need your cable size and brand that goes to the amp bro, then we can help 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Bmike Posted April 15, 2011 Report Posted April 15, 2011 heck is your voltage dropping, i know it sounds silly but if it is, it will also cuase this to happen. also that amp its rated to do 150 x2 @ 4 ohm 300 x2 @ 2 ohm 600 x1 @ 4 ohm so make sure you got your ohms set correctly or it could also be a factor, what type of fuse also,i tried to search to find out but not enough info, are they on the amp, external, maxi fuse ect.. need a tad bit more to go on, so we can help you out. 2007 trailblazer lthead unit- pioneer p4300dvd crescendo ft-1 supertweeters pioneer m650 pros audiocontrol 2xs crossover Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
CWorthington Posted April 16, 2011 Author Report Posted April 16, 2011 Nevermind. I would of just used an 100 amp fuse inline. Running 4 awg wire brand is xxx i think and was using a 80 amp glass fuse. There are 3 30 amp fuses on the block but i also use a main just in case. Its good now. Im not running with this amp anyways. I need to add another battery get a better alternator and do the big 3 before i upgrade my amp.
