what are you going to be putting in this thing?..
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
if you've got 10 batteries in the back, then anything more than 2 or 3 positive and negative runs of 0ga cable is doing nothing.,,
x2 multi runs like that are good if you only had front batt in street classes
R.I.P!
(Nov-29-2009)
92 explorer
current build
no probs i understand what you saying but i dont have the bats or the trunk floor cut yet so this is the reason i've added this many cables from the begining worth testing in the long run
keep the comments flowwing guys loving the feed back from every one :good:
1/0ga wire can carry about 150-200A as far as im aware. if he is running 600-900A coming from the alts and wants as much of that as possible transferred to the back im pretty sure he is 'doing it right' lol
Edit: Apparently im wrong... looks like i need a new source of info
Live life to the full... Then TURN THAT BITCH UP!
to start i'll be using one of these:
and two 10" subs lets see whre i land up with that,
But the final plan is to run 2 x 12" or 15" subs on two of these amps
Like i said the reason for so many power cables is for efficiency untill i purchase batts etc
yip i agree for now thats all i will have and one at the back.
:drinks: thanks for info buddy, this build is going to get crazy :yahoo:
