07 Tacoma walled off with 4 15's
Great looking install !! :drinks:
Kenwood KDC-BT33
Sundown Audio SAE-100.4  -  4 Crescendo Audio SC-650s
Sundown Audio SCV-6000D  @  (.5 ohm) ‎  -   2 DC Audio LVL5 M5 Elite 15s (d2)
6.45 ft Box ( Net ) tuned to 30 Hz  -   (  APM - 2  = 151.2 db  )
2004 Chevrolet Trailblazer LS 4WD
Brand X 390 Alternator - XS Power PSC30
XS Power D3400  (front)  -  3 XS Power D3100s  (rear)
Knukoncepts Kolossus Flex 1/0  -  SMD Meters  -  SMD Fuse Holders
Sky High Copper Battery Terminals  -  Amp Lab RPMC v2
SPL Cartel Bass Knob  -  Toolmaker Copper Amp Inputs
Got some updates,
I took the box out of the truck and did some body work on the port, painted it the color of the truck and I also redid the wiring in the box so that you can't see the speaker wire behind the port. Each connection for the speaker wires are soldered and heat shrunk. I used brass hardware as terminals for the wires and glassed up the hole where the original wire was going through. Everything is wired up to two ohms.
I also wrapped the back of the trim panel with some black carpet and put the back pillars on so that it's a little bit neater with the rear doors open.
I am going to put some blue led's in the port but I am waiting on them to be shipped, it might be another week or so for that.
Fucking sexy man!!! i honestly want to see a TL score on this bitch, i´m pretty sure it should score a very good number using those cheap subs, get some termlab time :)
