my buddy is trying to decide which amp to run his 3 soundstream splx hx there rated @ 1000rms and i cant help him with deciding on an amp.. so maybe anyone on here could.. hes going to be running them at .5ohm to the amp and has all the electrical upgrades and what not to run them but hes looking at a crescendo 3k or a DC 3.5k or Audioque 3.5k amp... any ideas on which would be the ideal amp for his layout.. thanks
crescendo amp : http://www.crescendoaudio.com/product.php?productid=17515&cat=249&bestseller=Y
audioque: http://www.audioque.com/AQ3500D1-Amplifier_p_32.html
dc audio : http://www.dcsoundlab.com/amps.html
Edited by st^^
No amp is really ideal to run at .5 ohms. From what i know, it voids the warranty also.
Each of the amps listed are good amps, but i wouldn't be caught dead running them at .5 ohm daily.
Has he got the subs already?
The closer to 2 ohms you can get them running, for a daily, the better off he will be. Some amps thrive on 1 ohm loads, so you have to check that out. Most amps won't last too long if you are running .5 ohm load all day every day.
BassinBlazer
JL[RF][Kenwood][AQ]
I need a new amp! Sell me your amp!
there dual 2 ohms subs.. idk how he is going to what to run them.. he just told me to post a topic on those 3 amps and hes trying to get them to run at .5 ohms. but if you all say that 2 ohms is better than i will relay that message to him.
Unless he is going to be doing comps and burping the subs, he probably doesn't want to run them at .5 ohm. 1 ohm iffy, 2 ohms great. .5 ohm....ehhhhh....I wouldn't. I ran a 2ohm amp at 1 ohm for a year straight, it dealt with it. As soon as I wired it down to .5 ohm with different subs, it played for about 2 minutes then went into thermal protection mode. Wired it back to 1 ohm again with the other subs and it ran fine.
If the amp handles it, great, if not, you might just be wasting money.
I don't know if he looked at these yet, but soundstream is RMS rated at .5 ohms. Soundstream 2.6K RMS amp
Edited by bassinblazer
BassinBlazer
JL[RF][Kenwood][AQ]
