i cant decide what i need/want to do i have to get an alt either way for my 91 c1500 i can either run a dual setup with my stock alt/ batt and run a separate voltage for the amps either 14 or 16v (most likely 16v because if i have to split it i might as well make it worth it) i can also just run a single alt and build a very strong 12v system or i can do as i planned before and run a 14v system for the whole truck but i really want to stay away from using stepdowns unless someone can justify the cost of them over just running a completely separate charging system all together
thanks
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
What about dual alts running a single 12v electrical system?
What amps do you have?
Edit: just reread the OP. If you're limited to just one alt, I would advise you to just stay at 12v because if a stepdown fails, you could be fucked
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
If I was in your position, I wouldn't run separate charging systems. And I definitely think 16 volts is rarely worth the trouble.
I would work on a single alt setup with a battery bank to compensate if you really need. What amps are you using?
im not limited to 1 alt my truck is pretty common so alts are easy to get
i will be running a SAZ3500 i talked to jacob today and he said they are stable to 19v so charging at 18.9 for a 16v system isnt a problem
i have thought about running both alts for a single 12v system
What nominal impedance will the SAZ be wired to? I assume 1 ohm.
Also, will you be competing at all?
If not, 19v wouldn't be worth the hassle and money to me.
Edited by hdorre
LMFAO so true
:blush:
I'm not talking about the amps being the issue, I only asked that to calculate draw.
holy tripple post
anyway... so your saying that going from 3500 watts at 12v to 5670 at 18.9 i wouldnt hear the difference?
Shit, I miscalculated...sorry :(
I would only recommend you to run at 19v if you had a COMPLETE second electrical system (2nd alt and 16v batteries) and if you knew how to wire it (which either you or N8 probably do)
LMFAO so true
:blush:
yeah the only reason i was considering 16v batts because they are the same price or very close in price as the 14v
